Activity › Forums › Apple OS X › Getting 80 gig as date onto DVD
  • Getting 80 gig as date onto DVD
    Posted by Dan Davis on August 1, 2011 at 2:21 pm
    Hi all,
    I have a 1 hour ProRes 422 HQ prog. Clent wants it burnt onto DVD as data.
    Can anyone recommend the best way of compressing this down to fit.
    Thanks for any advice!
    Dan.
    Matt Doe replied 15 years, 1 month ago 2 Members · 3 Replies
  • Matt Doe
    August 1, 2011 at 3:06 pm
    Assuming you have access to Compressor, use that to make an h264.
    You’ll probably have to tweak the settings a bit to get it down to fit on a DVD. Do they want an HD file, or would an SD frame size be acceptable?
  • Dan Davis
    August 1, 2011 at 3:19 pm
    Thanks for that! they’ll be happy with SD.
    Dan.
  • Matt Doe
    August 1, 2011 at 8:10 pm
    I would go with a 960×540 h264 and see where the file size ends up.
