Activity Forums Apple Final Cut Pro Legacy Getting 2 different aspect ratios upon output from the same timeline
  • Getting 2 different aspect ratios upon output from the same timeline
    Posted by Erich on December 14, 2005 at 7:23 pm
    I have an indpendent feature shot on the Panasonic DVX 100A 24p that I cut in FCP5. In addition to the footage, my opening includes several jpeg images that are refusing to project at the same aspect ratio as the video. Both elements are coming from a the same timeline and thus have identical settings. At the test projection today, the stills went out at 1.77:1 and the 24p footage was at 1.66:1. Does anyone know what I need to do to correct this issue. Also, what are the bst sequence settings for 24p in general. I noticed a change in my sequence window when switching between 3:2, and 16:9 anamorphic, but very little difference on my external viewing monitor. Is one setting more ideal than the others for both editing and output?
    Erich Hoberg
    Jordan Woods replied 20 years, 8 months ago 2 Members · 1 Reply
  • Jordan Woods
    December 14, 2005 at 10:30 pm
    sounds like your sequence is not fit for what was shot on the 24P(not anamorphic timeline)… therefore it allowed the jpeg’s to fill the screen. make your jpeg’s fit the same image as your 24p— bring them in slightly bigger and shrink them down in FCP(easy route). Or crop the Jpegs to look just like the 24p— anything like that will work- don’t touch the sequence settings on the 24p, or you’ll end up in trouble. I might be imagining the wrong scenario here, but that’s what I got.
