Activity Forums Blackmagic Design Getting 1.4 frame-packed output from FCP thru Extreme 3D to 3D monitor
  • Getting 1.4 frame-packed output from FCP thru Extreme 3D to 3D monitor
    Posted by Kevin Petajan on May 31, 2011 at 5:52 pm
    Hi, we’ve been figuring out our workflow on a 3D project that we’ve been working on. We are in the process of choosing a 3D card for preview, and possibly final output. Question: can you use a Decklink plugin in FCP to output frame-packed 1.4? Do you need a Dashwood Toolbox 3D plugin, Cineform, to pull the two streams together? As far as I know, the Dashwood plugin will only to Interleaved or superimposed, not full resolution frames.
    Or, is the Extreme 3D card really just set up for playback of two pre-composed L & R files?
    Kevin
    Kevin Petajan
    Kevin Petajan replied 15 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
