Activity Forums Adobe Premiere Pro getting 1080 slo mo in a premiere pro timeline with a 5d Mark iii
  • getting 1080 slo mo in a premiere pro timeline with a 5d Mark iii
    Posted by Gavin Williams on September 25, 2013 at 1:55 pm
    Hi
    I have a 5d Mark III and want to shoot a few things in Slow Motion (50fps in 720 in the 5D settings). I then conform these slo mo shots in Cinema Tools and use in my Premiere Pro timeline. However I want the new film to be 1080 quality – but how do I go about upscaling and at what point do I do that?
    Gav
    Walter Soyka replied 12 years, 11 months ago 3 Members · 4 Replies
  • Jeff Pulera
    September 25, 2013 at 2:09 pm
    Hi Gav,
    You could work in a 720p sequence and simply choose 1080p during export. Or create a 1080p sequence for the 720p clips. Should be same quality either way. In Prefs, there is a checkbox for “Scale to Frame Size”. This will auto-scale any clip to match the sequence upon import. Does not affect clips imported before the change. For those, right-click a clip on the timeline and manually check Scale to Frame.
    I’m not experienced with the slow-mo question and am not addressing that end of it.
    I should ask, are you mixing the 720p clips with 1080p source material at all? That makes a difference. If so, then of course use a 1080p sequence for all clips together.
    Jeff Pulera
    Safe Harbor Computers
  • Gavin Williams
    September 25, 2013 at 2:18 pm
    Hi Jeff
    Thanks for the response – much appreciated
    I am shooting most the other clips at 1080 so will have a 1080 sequence for sure. How much quality will be lost in the upscaling of the slow motion footage – is it highly noticeable?
    Gav
  • Jeff Pulera
    September 25, 2013 at 2:52 pm
    720p actually scales up to 1080p pretty well and should not be a problem. Try a quick sample with your workflow to make your own determination of course. If you could actually edit/deliver in 720p, that would be ideal, but you should be ok at 1080p.
    Jeff Pulera
  • Walter Soyka
    September 25, 2013 at 4:13 pm
    [Gavin Williams] “I then conform these slo mo shots in Cinema Tools and use in my Premiere Pro timeline.”
    FYI, you don’t need Cinema Tools. You can simply right-click a clip in the Premiere project panel, then choose Modify > Interpret footage, and finally put in your new frame rate.
    Walter Soyka
