Activity Forums Adobe After Effects Expressions Get Values from Layers Name
  • Get Values from Layers Name
    Posted by Sebastian Martinez on May 9, 2020 at 2:55 pm
    Dear expression heroes,
    I’m using expressions regulary but I can’t wrap my brain around this and I already searched the forum without any results:
    I have a comp with a length of 1000 frames.
    Within this comp is a Shape-Layer named 09:00_0010_0990.
    I want to reveal the path by trimming the End-Value from frame 10 (0%) to frame 990 (100%).
    How can I target the last two digits in the layer name (0010 and 0990) for this instead setting keyframes?
    The hour at the beginning of the layer’s name has a structural importance for the project’s structure but is irrelevant for the animation itself.
    Thank you in advance if there is any solution!
    Sebastian
    Sebastian Martinez
    CGI-Designer
    Cologne, Germany
    AE, AI, PS, 3ds max, C4d
    Sebastian Martinez replied 6 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 9, 2020 at 3:56 pm
    Probably something close to this:
    splitName = name.split(“_”);
    tStart = framesToTime(parseInt(splitName[1],10));
    tEnd = framesToTime(parseInt(splitName[2],10));
    linear(time,tStart,tEnd,0,100)
    Dan
  • Sebastian Martinez
    May 9, 2020 at 4:05 pm
    Dan,
    that’s exactly it! Perfect, you are magic!
    Dearest respacts and thank you so much again!
    Sebastian
    Sebastian Martinez
    CGI-Designer
    Cologne, Germany
