Activity Forums Adobe After Effects Expressions Get time value in seconds of keyframes in a given range
  • Get time value in seconds of keyframes in a given range
    Posted by Reuben Lara on October 9, 2020 at 12:11 am
    I’m able to access all the values of a range of keyframe on a specific prperty, but how can I know when in time they are? Looking to fill the variable “keyframeTime” below. Thanks!
    var position = selection[i].property(“ADBE Transform Group”).property(“ADBE Position”);
    if(position.numKeys>0){
    for (k=1;k<position.numKeys;k++){
    var posValues = position.keyValue(k);
    var posX = posValues[0];
    var posY = posValues[1];
    var keyframeTime = ???
    Reuben Lara replied 5 years, 11 months ago 3 Members · 3 Replies
  • Dan Ebberts
    October 9, 2020 at 12:19 am
    It would be:
    var keyframeTime = position.keyTime(k)
    Also, if you want to examine all the keyframes, including the last one, your loop should be using:
    k <= position.numKeys
  • Stephen Dixon
    October 9, 2020 at 12:22 am
    keyframes have a time property so the line would be:
    let keyframeTime = position.key(k).time
    You can access all the properties of keyframes this way, e.g.
    let keyframeValue = position.key(k).value
    more info about keyframes in expressions here
  • Reuben Lara
    October 9, 2020 at 2:04 am
    excellent, thank you as always! your dedication to providing answers here is mesmerising, we all appreciate your commitment!
