Activity › Forums › Maxon Cinema 4D › Get texture from image
  • Get texture from image
    Posted by Mohamed Ahmed on August 12, 2019 at 7:26 pm
    Hi all,
    I’m new here
    Also I’m still training to learn cinema 4d
    I have to modeling an building based on photo
    That photo have many colors and decorate colors too
    Any way to convert the photo as a textures for my model?
    I downloaded photo from shuterstock before buy it for my trying
    John Williams replied 7 years, 1 month ago 2 Members · 1 Reply
  • John Williams
    August 13, 2019 at 1:42 pm
    Hi there, you certainly wouldn’t want to recreate that texture as it’s quite complex so your quickest option would probably to do some projection mapping onto your model.
    The model looks quite simple to recreate, in fact it looks like you only need one arch and the other two can be copies. Then if your texture is high enough resolution (i expect the purchased version will be) then you can project the texture onto the model.
    John Williams
    Soho Editors
