Activity Forums Adobe After Effects Expressions Get Text from datasheet
  • Get Text from datasheet
    Posted by Wilhelm Hagberg on August 21, 2007 at 9:15 pm
    Im making a simple animation with Source text. In each keyframe, I want a certain text to appear. I would like to take those texts from an Ms Excel Datasheet. Does anyone know how
    to achieve this…
    Best, WTK
    Kevin Camp replied 19 years, 1 month ago 3 Members · 2 Replies
  • Colin Braley
    August 22, 2007 at 2:09 am
    You can’t do this with expressions, you need to use scripting. Try searching the forums at aenhancers.com, maybe you will find something you can modify and use.
    ~Colin
    ~Colin
    http://www.colinbraley.com
  • Kevin Camp
    August 22, 2007 at 2:07 pm
    dan ebberts also has a script on his site for creating text layers for file. i believe it will create a new text layer for evry line of text in a text file… you would need to export your spreadsheet to a text file, and hopefully be able to set it to export each cell as a new line. or modify the script to look for tabs, rather than new lines.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
