Activity Forums Adobe Premiere Pro get sound in Source but not Sequence window
  • get sound in Source but not Sequence window
    Posted by Anhtu Vu on May 14, 2013 at 3:58 am
    I just imported an XML from FCP7 and my sequence has no sound even if i can see the waveform on the audio tracks. If i play the clip from the Source window by double clicking it from the sequence then i get sound. Any idea ???
    I’m using a MBP with IO XT and Pegasus R4. Thanks
    Anhtu Vu replied 13 years, 3 months ago 4 Members · 4 Replies
  • Ivan Myles
    May 14, 2013 at 4:36 am
    Check each of the following parameters:
    Track mute in the Program panel
    Volume setting in the Effect Controls panel for the clip
    Audio Gain… under the menu item Clip > Audio Options (or right click the clip)
    Track mute in the Audio Mixer panel
    Track audio level in the Audio Mixer panel
    Master audio level in the Audio Mixer panel
  • Kris Merkel
    May 14, 2013 at 10:29 am
    You can also look at the audio output settings in your audio prefs to make sure that the ioXT is set as the audio output also check your output mapping. It also could be just an incompatibility between the source audio sample rate and the sequence’s sample rate.
    Can you hear the audio from the sequence when the settings are set to computer audio only?
    How many channels of audio did the original fcp sequence have?
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Victor Perez
    May 14, 2013 at 5:18 pm
    Occasionally when opening an XML for the first time from FCP in Premiere CS6 I notice the volume in the sequence is at -∞. I can hear it in the Source monitor, but not in the Sequence. Dragging up the volume to 0.0 db usually does the trick. If you have keyframes set there might be additional problems.
    Victor
    editvictor.com
    http://www.hbhm.tv
    http://www.itvisus.com
  • Anhtu Vu
    May 15, 2013 at 3:16 am
    Alright i found the problem this is definitely a CS6 bug….but how can i fix this ….basically, the volume on each clip is at -infinity…therefore i need to raise the volume…the only problem is that i have thousands of clips as this is a 120 min doc with tons of edits!!!!
