Activity Forums Avid Media Composer Get Smooth Playing
  • Get Smooth Playing
    Posted by Ángel Molina lópez on June 11, 2019 at 7:58 pm
    Hi everyone:
    Recently, I gave a video encoded with the h264 to a colleague in order to dub it but when she put the file into Pro Tools the playback was not smooth at times. I have read that it is a mistake to encode a video in h264 for Pro Tools so I have been looking for the codecs supported by the software. Apparently, all codecs create very large files. Isn’t there a codec for Pro Tools that creates normal file sizes?
    Thanks.
    Ángel Molina lópez replied 7 years, 3 months ago 3 Members · 3 Replies
  • Oliver Peters
    June 11, 2019 at 11:26 pm
    ProTools should be able to work with H.264. What are the specs of the file? Data rate, FPS, size, wrapper? Alternative codecs would be Apple ProResProxy or Avid DNxHD36.
    – Oliver
    Oliver Peters – oliverpeters.com
  • John Pale
    June 12, 2019 at 12:44 pm
    I’d always given h.264 until recently, when my mixer asked for ProRes LT. ProRes proxy should be fine too. The key is being an I-Frame codec, as it’s less processsor intensive. File size is less important.
  • Ángel Molina López Create COW Profile Image
    Ángel Molina lópez
    June 12, 2019 at 2:53 pm
    These are the specs. Sorry if I’ve gone too far providing information haha.
    General
    Complete name : E:PelisHouse 3×14.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 835 MiB
    Duration : 43 min 54 s
    Overall bit rate : 2 657 kb/s
    Writing application : Lavf58.12.100
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate : 2 400 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (23976/1000) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.048
    Stream size : 752 MiB (90%)
    Writing library : x264 core 148
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2400 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Menus : 3
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Constant
    Bit rate : 257 kb/s
    Channel(s) : 6 channels
    Channel layout : C L R Ls Rs LFE
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 80.6 MiB (10%)
