Activity › Forums › Adobe Premiere Pro › Get rid of Popping “P” in a voice over,
  • Get rid of Popping “P” in a voice over,
    Posted by Adam Berch on November 21, 2020 at 4:56 pm
    I recorded a Voice Over into a Zoom and when I put it into Premiere Pro, every time he says a word with a “P” in it, there is a popping sound.
    How can I get rid of the ‘P” popping sound?
    Thanks in advance
    Jim Curtis replied 5 years, 10 months ago 7 Members · 6 Replies
  • Larry Chapman
    November 22, 2020 at 6:48 pm
    I would try a high pass filter first. See if you can reduce the pop significantly without negatively impacting the voice too much. You’ll have to experiment with the frequency.
  • Peter Groom
    November 22, 2020 at 8:46 pm
    Izotope rx addresses this issue perfectly, although correct mic positioning and recording in the first place is the real solution
    Peter
  • John Vlach
    December 1, 2020 at 12:55 am
    I would keyframe the audio clip volume around the times “p” is said. Then pull down the level in the areas so that it is not as loud, making it softer.
  • Andy Ford
    December 1, 2020 at 10:48 pm
    These are called plosives and you can lessen them with EQ and volume changes around the affected area or, if using Audition, you could apply the FFT filter to the area of concern and dial in the settings.
  • Santanu Bhattacharjee
    December 2, 2020 at 9:33 pm
    Select only the P. Apply a bass cut around < 200Hz. It should do the job.
  • Jim Curtis
    December 2, 2020 at 9:42 pm
    Another method is to set your Timeline to Audio Time Units, unlink the audio from the video, zoom in to the plosives, and snip them out. They are usually a small number of samples in duration, and probably won’t affect your sync visibly.
    There are other plosive reducing plug-ins on the market than iZotope RX. Accusonus has one.
