Activity › Forums › Apple Motion › Get overlapping text to reveal third layer in Motion 3- HOW?
  • Get overlapping text to reveal third layer in Motion 3- HOW?
    Posted by Geoffrey Arnold on June 1, 2008 at 6:06 pm
    How can I Get a Third layer to appear in the letters (only) where two separate text layers intersect as they pass each other?
    Any Ideas
    Thanks, Geoff
    Stephen Smith replied 18 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Stephen Smith
    June 2, 2008 at 2:28 pm
    Place the two text layers in a group above your third layer. Make the group with the two text layers a Stencil Luma or Stencil Alpha Blend Mode. Hope this helps.
    Stephen Smith
    Lone Peak Producitons
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • Burt Hazard
    June 2, 2008 at 4:00 pm
    I would just add that if you wanted to see the text as well you could use the following recipe:
    Group 1 Normal
    Text 1 Stencil Alpha
    Text 2 Stencil Alpha
    BG Graphic Normal
    Group 2 Pass Through
    Text 1 Copy Normal
    Text 2 Copy Normal
    Actually Stephen’s method results in a much more interstesting effect anyway; when I was playin’ around in Motion this morning I realized this has nice fututure possibilities for quasi-abstract text backgrounds.
  • Stephen Smith
    June 2, 2008 at 4:24 pm
    Oh, I see…I intrepid the questions wrong. Great recipe Burt!
    Stephen Smith
  • Geoffrey Arnold
    June 2, 2008 at 6:56 pm
    Thanks Stephen and Burt that works perfect, one more question though
    can I mirror the position properties on the duplicate text layer automatically?
    Thanks, Geoff
  • Stephen Smith
    June 2, 2008 at 6:59 pm
    Are you asking that the text potion be the same for both text layers?
    Stephen Smith
  • Geoffrey Arnold
    June 2, 2008 at 7:15 pm
    Hi, Stephen
    I’d like to get the position etc from effect text layer to the visible “copy” layer (without manually copying the keys)
    Group 1 Normal
    Text 1 Stencil Alpha (position,etc from here)
    BG Graphic Normal
    Text 1 Copy Normal (to here)
    Text 2 Copy Normal
    Thanks, Geoff
  • Stephen Smith
    June 2, 2008 at 8:32 pm
    If you select the “Group 1 normal” layer and hit the Command and D keys it will make a duplicate of that layer. Change the blend modes to resemble the recipe for the 2nd group.
    If you already did that and changed the text so they no longer line up, do the following. To select certain parameters such as position select it/them in the Inspector. Drag your cursor over to your Project Pane or Timeline. Hover the curser over the text you want to apply the parameters to and the curser arrow will turn into a curved/hocked shaped arrow. It will then take on those parameters. Hope that helps.
    Stephen Smith
