Activity Forums Adobe After Effects Expressions get name from effect controls and add them to expression
  • get name from effect controls and add them to expression
    Posted by Sam Catt on May 16, 2018 at 10:05 pm
    So i’ve been pondering on this for a while now.
    I want to select a layer and, in an AE UI input text field specify how many iterations of an effect control I want: I.E
    Target 1
    Target 2
    Target 3
    Target 4
    Target 5
    etc etc. I have this working perfectly. Now I want to be able to take the effect control names and add them to the layers expression
    I.E:
    – start of expression here –
    target 1
    target 2
    target 3
    target 4
    target 5
    – end of expression here –
    my guess, is I would have to create an array? and then link back to the arrays name in the expression = “”;
    Though I have no idea how to actually go about doing that exact thing. My current code is below, ignore the “5” in for (var n = 0; n < 5; n++){ it’s a dummy for selecting 5 in te UI text box
    app.beginUndoGroup("Dynamic Parenting");
    var myComp = app.project.activeItem;
    if (myComp == null || !(myComp instanceof CompItem)){
    alert(errorNoCompSelected);
    } else {
    var selectedLayers = myComp.selectedLayers;
    if (selectedLayers.length==0) {
    alert(errorNoLayerSelected);
    } else {
    for (var i = 0; i &lt; selectedLayers.length; i++){
    selectedLayers[i].property("Rotation").expression = "Target 1";
    var effectLocation = selectedLayers[0].property("Effects");
    var effectCount = effectLocation.numProperties;
    for (var n = 0; n &lt; 5; n++){
    var addEffect = selectedLayers[0].property("Effects").addProperty("Layer Control");
    var nPlusOne = n+1
    addEffect.name = "target" + " \""+nPlusOne+"\" ";
    var addEffect = selectedLayers[0].property("Effects").addProperty("Slider Control");
    addEffect.name = "fade" + " \""+nPlusOne+"\" ";
    for (var m = 1; m &lt;= 1; m++){
    var currentExpression = selectedLayers[0].property("Rotation").expression;
    selectedLayers[0].property("Rotation").expression = " \""+currentExpression+"\" " + "something";
    app.endUndoGroup();
    Sam Catt replied 8 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
