Activity Forums Adobe After Effects Expressions Get Max value from graphic.
  • Dan Ebberts
    June 15, 2025 at 7:06 am
    Not directly from the graph editor, but you can analyze whatever property is driving the graph, with something like this:
    prop = thisComp.layer("White Solid 1").effect("Slider Control")("Slider");
    for (i = 0; i <= thisComp.duration; i += thisComp.frameDuration){
    max = (i == 0) ? prop.valueAtTime(i) : Math.max (max, prop.valueAtTime(i));
    max
    but there will be a tradeoff between resolution and processing time. The example above checks the value every frame, but you could change it to check more often if you need finer resolution.
  • Smet Kira
    June 15, 2025 at 9:03 am
    Bless you sir Dan!
