Activity Forums Adobe After Effects Get Localize Path with scripting
  • Get Localize Path with scripting
    Posted by Meng Zhiqun on November 21, 2021 at 2:36 am
    Hello,
    I have a script which requires the full path of the folder and object. Everything works smoothly, however, that is if the user’s os language is set to English.
    I know for a fact, based on AE’s javascript tool guide, we can temporarily set the locale to a different language to test the locale. For example this example works.
    message = { en_GB: "Please select a colour.",
    en: "Please select a colour.",
    de: "Bitte wählen Sie eine Farbe.",
    $.locale = "de"; // spanish
    alert(localize(message));
    $.locale = null; // restore to the locale of the app
    However, when I try to target it with a Folder.selectDialog() to try to get the localize path of the folder, it doesn’t work.
    $.locale = "es"; // spanish var chooseFol = Folder.selectDialog();
    alert(localize(chooseFol.fsName));
    For eg. If I select the Documents folder with the above, it still shows “C:\Users\Username\Documents”, however I know for a fact that if the language is set to Spanish, Documents would be listed as Documento, which has been breaking my script. I hope someone has some insights.
    Thanks in advance!
    Meng Zhiqun replied 4 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
