Activity Forums Adobe After Effects Expressions Get Largest Rectangle Path Size From Different Shape Layers
  • Get Largest Rectangle Path Size From Different Shape Layers
    Posted by Shane Starnes on March 28, 2024 at 9:22 pm
    I need to grab layer(“A”+n).content(“Rectangle Path 1”).size[0] from each shape layer starting from A1, A2, etc and set a Point Control to the maximum number, regardless of how many shapes with rectangles I add. Is this possible? I imagine there’s a for loop alongside a try catch to see if the layer has a Rectangle Path 1, but I’m having trouble putting everything together.
    Brie Clayton replied 2 years, 5 months ago 3 Members · 3 Replies
  • Dan Ebberts
    March 28, 2024 at 9:34 pm
    The name testing could be more robust, but this might get the job done for you. I’m not sure why you’d use a point control if you’re only interested in the x dimension, but here it is:
    max = 0;
    for (i = 1; i <= thisComp.numLayers; i++){
    if (thisComp.layer(i).name[0] == "A"){
    try{
    x = thisComp.layer(i).content("Rectangle 1").content("Rectangle Path 1").size[0];
    max = Math.max(max,x);
    }catch(e){
    [max,0]
  • Shane Starnes
    April 1, 2024 at 3:28 pm
    Ah, good point about the point control, my idea was morphing as I typed the original message
    😅 Works flawlessly though. As always, great work Dan and thank you for the assist!
  • Brie Clayton
    April 2, 2024 at 2:53 pm
    Thank you for solving this, Dan!
