Activity Forums Adobe After Effects Expressions Get folder path and save the path in local storage until the path is changed.
  • Get folder path and save the path in local storage until the path is changed.
    Posted by Nathaniel Logan on October 28, 2018 at 12:23 pm
    Hi im new to After effects scripting,
    Im trying to get the file path from the folder that is being selected.
    Lets say i have a project folder in my local drive and I navigate the Dialog to that project folder.
    But the problem is every time i restart the application that i need to select the folder path.
    Is there a way that i can save the path in localStorage and fetch the temp path from here, unless the project folder is in the same path.
    var selectFolder = Folder.selectDialog("Select the Project Folder...");
    alert(selectFolder.fsName);
    Nathaniel Logan replied 7 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
