Activity Forums Adobe After Effects Expressions Get Deformed Shape Path Data
  • Get Deformed Shape Path Data
    Posted by Nils Hammers on August 29, 2023 at 2:47 pm
    Hi there,
    Is it possible to get resulting data from Shape layer path, that has operators applied, such as Merge and WigglePaths, to be fed into another ShapePath/MaskPath property. Call it “code level precompose”.
    Alternatively, are there code snippets that would emulate those vector filters?
    What I am after is to use Scribble effect on a MaskPath, that has those deformations, or whatever scribbly result that would work on shape directly.
    EH
    Nils Hammers replied 3 years ago 2 Members · 2 Replies
  • Filip Vandueren
    September 1, 2023 at 11:09 am
    Hi Nils,
    There’s no way to do that directly.
    Some effects can be mimicked with expressions, for example by simulating our own Wiggle Paths/Wiggle Transforms via a createPath() expression.
    But merging Paths is not do-able I think. For one, it’s very hard to program that logic into an expression, and apart from that: 1 Path property must always just contain one “string” of vertices, not a compound path such as can be created with a merge/subtract operation…
  • Nils Hammers
    September 1, 2023 at 1:27 pm
    Hi Filip,
    Thank you for your answer, yet the news You’ve brought were kind of sad. 🙂
    Having an intermediate knowledge of AFX expressions, I was inspired by CreateNullsFromPaths script and https://ae-scripting.docsforadobe.dev/matchnames/layer/shapelayer.html and was hoping there is something esoteric, like
    …(“ADBE Root Vectors Group”)(1)(“ADBE Vectors Group”)(1)(“ADBE Vector Shape”)…
    with some magic of
    …(ADBE Vector Filter – Roughen)…
    and
    …points()
    that would output the data that is being rendered.
    I suspected some wiggly things could be done with createPath(), and then, from what you say, I conclude I should work with masks directly, as Scribble supports mask modes, and I would be able to simulate boolean behavior.
