Activity › Forums › Adobe After Effects Expressions › Get average colour from layer based on target objects area
Posted by Jamie Shiels on October 1, 2014 at 5:45 amHi,
Im after an expression to find the average color of an image based on the target layers area. I am creating a countryside field patchwork image and am tracing around some old aerial pics. I want to grab the average colour of the original pic based on the area of the shape not the pictures anchor point.
Jamie
Jamie Shiels replied 11 years, 11 months ago 2 Members · 6 Replies -
Dan Ebberts
October 1, 2014 at 6:40 amI’m not sure I understand completely, and you didn’t specify where this expression will be applied, but it will probably be something like this:
L1 = thisComp.layer(“target”);
L2 = thisComp.layer(“image”);
p = L2.fromComp(L1.toComp(L1.anchorPoint));
avgColor = L2.sampleImage(p,[L1.width,L1.height]/2,true,time)Dan
Jamie Shiels
October 1, 2014 at 6:54 amHi Dan,
Thanks for the speedy post and sorry for not being clearer. I have a composition with about 130 individual shape layers that I want to get an average colour from an image for each of the shapes. I wanted to use an expression on the shapes colour or it could use it on a fill effect that applies the average colour to the shape based on the shapes area. I can’t use anchor points because if you use the images anchor point all the shapes will have the same colour and the shapes anchor point is the centre of the comp so thats no use either. It would be great if the expression automatically set the area based on the shape it was applied to so I didn’t have to manually change the expression for each shape.
I hope this is clearer.
Jamie
Dan Ebberts
October 1, 2014 at 6:01 pmThis seems to work for the fill color of rectangular shapes:
L = thisComp.layer(“image”);
p = L.fromComp(toComp(anchorPoint)+content(“Rectangle 1”).transform.position);
avgColor = L.sampleImage(p,content(“Rectangle 1”).content(“Rectangle Path 1”).size/2,true,time)Dan
Jamie Shiels
October 2, 2014 at 5:16 amHi Dan,
Thanks for this, it works a treat on rectangular shape layers but because Im re-creating a “patchwork of fields” effect I need to use bezier paths. Is there a way to adapt this expression for beziers?
Jamie
Dan Ebberts
October 2, 2014 at 6:46 amUnfortunately, I can’t think of a practical way to do it with beziers.
Dan
