Activity Forums Adobe After Effects Expressions Get absolute transform values? (3D parented objects)
  • Get absolute transform values? (3D parented objects)
    Posted by Tyler Joynt on January 24, 2014 at 4:05 pm
    I’m building a pretty simple animation, but I know I could use this in other places too.
    Basically its a 3×3 grid of rectangles that rotate in 3D space and reveal something else on the other side.
    But I want to be able to write an expression so that when the front or back pieces reach a certain degrees, their Opacity goes to 0, so you can see the other side. Had issues with z-fighting and stuff, so figured this would be way more efficient than manually cutting layers.
    I found a Dan Ebberts script in here, but it was for 2D layers and I couldnt get it to work with 3D ones.
    Any ideas?
    Tyler Joynt replied 12 years, 7 months ago 2 Members · 3 Replies
  • Tyler Joynt
    January 24, 2014 at 4:38 pm
    Not exactly answering my question about absolutes, but I guess this works in finding it sorta manually:
    angle = transform.yRotation%360-thisComp.layer(“Null 1”).transform.yRotation;
    if (angle > 90)
    0
    else
    100
  • Dan Ebberts
    January 24, 2014 at 5:05 pm
    I’m guessing you’re not talking about this one:
    https://www.motionscript.com/design-guide/invisible-facing-away.html
    Dan
  • Tyler Joynt
    January 24, 2014 at 5:15 pm
    oh lord, how did i miss that.
    thanks a ton, that’s great!
