Activity Forums Adobe After Effects Expressions get a value at a certain keyframe
  • get a value at a certain keyframe
    Posted by Tom Gomez on May 29, 2013 at 10:42 pm
    Greetings Folks,
    Looking for a simple way to grab a value of a given property of a given layer at a certain keyframe on that property.
    Specifically, I’ve got a shape layer with a keyframed rectangle width (just two keyframes). I’m creating a matching rectangle that needs to START with the width the first one ended at.
    Thanks so much! People in this forum are amazing.
    -Tom
    YOU can help save TimeSpace. Join the Chronos Protectorate!
    https://www.95ers.com
    https://www.SpaceAceMedia.com
    Eduardo Asta replied 7 years, 2 months ago 4 Members · 6 Replies
  • Dan Ebberts
    May 29, 2013 at 11:31 pm
    Something like this should work:
    s = thisComp.layer(“Shape Layer 1”).content(“Rectangle 1”).content(“Rectangle Path 1”).size;
    s.valueAtTime(s.key(s.numKeys).time)[0]
    Dan
  • Tom Gomez
    May 30, 2013 at 3:58 pm
    As always thanks so much Dan.
    It was giving me an error (something about 2 dimensions) with the [0] so I removed it and it worked like a charm. Any idea why?
    Quick question: Where in that expression does it tell it to look at the second keyframe?
  • Dan Ebberts
    May 30, 2013 at 4:18 pm
    >Any idea why?
    You mentioned that you wanted the width, so the [0] isolates the width part of the 2D size parameter.
    The expression looks for the last keyframe, which is what s.numKeys does.
    Dan
  • Eduardo Asta
    July 19, 2019 at 4:06 pm
    Hello Dan,
    I have a similar problem. I have a shape layer with two key frames on Trim Paths. I want to grab the second Trim Paths keyframe value and link it to a slider.
    Do you if it is possible?
  • Tomas Bumbulevičius
    July 19, 2019 at 8:30 pm
    Eduardo – you can’t alter the value of keyframe itself by a slider.
    Instead of using keyframes, you could use interpolation methods, which can be controlled by sliders then.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Eduardo Asta
    July 19, 2019 at 10:07 pm
    Hello Thomas,
    I guess my question wasn’t clear. I could solve my problem using, yes, a liner method.
    Thanks for the website you sent to me. I didn’t know it.
    if (numKeys > 1){
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = 0;
    v2 = effect("Posicao")("Slider"); <----this one allows me to set by a slider the initial position of my layer
    linear(time,t1,t2,v1,v2);
    }else value
