Activity Forums Adobe After Effects Expressions Get 3D position given the 3D angle and distance
  • Get 3D position given the 3D angle and distance
    Posted by Noel Powell on September 2, 2023 at 6:37 pm
    I’m looking to position some layers in a sphere formation. I realize I could do this by parenting each layer to a separate Null Object, and then rotating the Nulls to make the layers orbit around to different positions on the sphere. But for the project I’m making, I would really prefer to do this with an expression if possible.
    This expression (from Dan Ebberts, I believe) works well to position a layer in a 2D circle around a center point, when given a Distance and Angle value:
    a = effect(“Angle Control”)(“Angle”);
    d = effect(“Slider Control”)(“Slider”);
    r = degreesToRadians(a-90);
    x = d*Math.cos(r);
    y = d*Math.sin(r);
    value + [x,y]
    So I’ve been trying to make a 3D version of this. Ideally, using a 3D Point Control to control the angle. Sorry, I’m not lazy, I’m just too dumb to figure this out. Thank you for your help.
    Brie Clayton replied 2 years, 12 months ago 3 Members · 3 Replies
  • Dan Ebberts
    September 2, 2023 at 7:16 pm
    I think I’d set it up with a slider for radius and angle controls for altitude and azimuth, like this:
    r = effect("Radius")("Slider");
    a = effect("Altitude")("Angle");
    az = effect("Azimuth")("Angle");
    center = [thisComp.width/2,thisComp.height/2,0];
    aRad = degreesToRadians(a);
    azRad = degreesToRadians(az);
    y = r*Math.sin(aRad);
    rXZ = r*Math.cos(aRad);
    x = rXZ*Math.cos(azRad);
    z = rXZ*Math.sin(azRad);
    center + [x,y,z]
  • Noel Powell
    September 3, 2023 at 12:30 am
    That works so perfectly, I can’t thank you enough, Dan! Your expression skills are legendary, and I’m so grateful.
  • Brie Clayton
    September 3, 2023 at 1:08 am
    Thank you for your solve, Dan!
