Activity Forums Maxon Cinema 4D Geometry Disappears in Cloner
  • Geometry Disappears in Cloner
    Posted by Lillian Young on March 5, 2011 at 9:55 pm
    I created a cloner, then a cube. When I dropped the cube into the cloner, it disappeared! I can render the object, but I cannot see it in the viewport while in production mode.
    All other functions seem okay.
    Not sure this is related, but when I installed GreyscaleGorila’s City Kit, I noticed that it would load, but not appear until rendered. I uninstalled that, but it had no effect on my cloner issue.
    Is there a way to just reset C4D R12 or restore preferences? This solves awkward behavior in Maya.
    Info:
    Mac Pro Quad-Core
    Snow Leopard 10.6.6
    Cinema 4D R12.032
    Brian Jones replied 14 years, 8 months ago 3 Members · 3 Replies
  • George Davis
    January 1, 2012 at 2:53 am
    I am having the exact same problem with version 12. It’s weird nobody responded to this.
  • George Davis
    January 2, 2012 at 6:41 am
    Lilian,
    I solved this problem on my own system, perhaps this will solve it on yours.
    In the camera view window(s), there is a pull down menu between “display” and “view” called “Filter.” Look through the options there. make sure that “Splines” is checked and viewable. Once I did this, I could see both splines and the objects inside of a mograph tool.
    Hopefully, that works for you, too.
    Good luck,
    George
  • Brian Jones
    January 2, 2012 at 6:51 am
    thanks for posting that George
