Activity Forums Maxon Cinema 4D geometry based shader OR geometry retracer? reconstruct an object out of berries
  • geometry based shader OR geometry retracer? reconstruct an object out of berries
    Posted by Anna Hahn on April 8, 2021 at 4:01 pm
    Hello!
    I have a mesh that I made that I would like to populate with berries ( a cartoon human form) ~ I would basically like to replace the mesh with an approximation of the mesh reconstructed out of berries, as if you had the body sculpted out of a pile of fruit
    What is the best way to achieve something like this in c4d in a quick and dirty way? I am okay with if there are strange artifacts etc if this means a less neurotic mesh re-interpretation process- I’m wondering if the approach would be to use a volumetric geometry based shader of a berry, a shader with a displacement map, or using some other functionality of c4d to reconstruct the body mesh out of clones of the berry mesh
    Justin Thomson replied 5 years, 5 months ago 2 Members · 3 Replies
  • Justin Thomson
    April 8, 2021 at 4:13 pm
    You can tell the cloner to use a mesh as a surface to clone onto. Just drop you cloned object into it, then set it to object mode. Adjust “distribution”, “Volume Mode” and “Count” as you see fit.
  • Anna Hahn
    April 8, 2021 at 5:23 pm
    Thank you so much for this~ is there a way to do it to control the distribution so that the berries are randomly sized/rotated etc?
  • Justin Thomson
    April 8, 2021 at 5:39 pm
    There is, you’ll find your answer if you research the Mograph effectors.
    https://help.maxon.net/us/index.html#7443
