Activity Forums Blackmagic Design Genlock on Blackmagic HD Plus – what’s it for?
  • Genlock on Blackmagic HD Plus – what’s it for?
    Posted by Darron on May 30, 2005 at 3:09 pm
    Hello one and all!
    I am considering getting either the Blackmagic HD or HD Plus card. The one thing that has me scratching my head is the Genlock feature on the HD Plus.
    Okay, I know what Genlock is for, but…um…what is it FOR? More directly, under what circumstances would I want the Genlock feature? How does this translate into real-world usage?
    In my thinking, I figure, “better to have it and not need it than to need it and not have it,” but considering I’ve been fat and happen with firewire until now…
    If anyone could enlighten this ignorant slob, I would be grateful!
    Darron
    Neil Sadwelkar replied 21 years, 3 months ago 3 Members · 4 Replies
  • Peter Wiggins
    May 30, 2005 at 4:00 pm
    [Darron] “Okay, I know what Genlock is for, but…um…what is it FOR? More directly, under what circumstances would I want the Genlock feature? How does this translate into real-world usage?
    It times your system into a larger setup, so you can feed a router input into your card and record. Or indeed feed your output into a matrix/router.
    This was first up when googled
    https://www.mivs.com/technical/appnotes/an005.html
    Peter
    https://www.peterwiggins.com
    In Paris editing The French Open for ESPN
  • Neil Sadwelkar
    May 30, 2005 at 9:53 pm
    You can use the genlock on the HD Plus card to feed in n external sync signal which is also fed to the Digi/Beta deck that you’re capturing from or outputting to. Mind that if you work in a large multi-suite facility with house sync that comes through a router or DA, the genlock in HDPlus or HDPro just plain doesn’t work. It gives a “picture roll” every once so often and you need to disconnect the genlock to make the HDPlus or HDPro work. This has been broken since BM ver. 4.7 onwards and I don’t know if its been fixed in ver. 5.0
    Neil
  • Darron
    May 30, 2005 at 10:52 pm
    Thanks guys, it’s getting clearer.
    Buuuuut, if the genlock is effectively broken when you have a router / DA supplying sync, then it seems a little bit useless…is that the case?
    Darron
  • Neil Sadwelkar
    June 2, 2005 at 3:29 am
    Yes it would seem so and this has ben my experience so far. That being said there is a driver update that is supposed to fix this. I will try this and report if there is any improvement.
    Neil
