Activity Forums Maxon Cinema 4D Genius or Noobie?
  • Genius or Noobie?
    Posted by Kelly Johnson on May 23, 2006 at 7:12 pm
    I’m a noobie in 3d, not just Cinema. But my question is, isn’t there some way to just draw a wireframe and have polygons mapped to that wireframe? Instead of having some shape and manipulating the existing wireframe?
    Is this too advanced or am I missing something?
    It seems, mechanically and from a programming pov, that it’s not unlike drawing a spline and being able to extrude ane revolve etc.
    Thanks for any help in clearing up what I’m missing.
    Björn Marl replied 20 years, 3 months ago 4 Members · 5 Replies
  • Brian Jones
    May 23, 2006 at 7:44 pm
    You can build by hand poly by poly, point by point. You can extrude a spline shape (ExtrudeNurb) you can sweep one spine along another spline (SweepNurb) you can spin a spline around an axis (LatheNurb) etc. There is no substitute for reading the docs, tryign some tutorials (try the QuickStart Manual) check out places like c4dcafe.com, pixel2life.com etc, etc…
  • Björn Marl
    May 24, 2006 at 7:15 am
    Drawing a wireframe and creating polygons is practicaly the same. The wires you see are the edges of polygons. You can’t get one without the other.
    Cheers
    Bj
  • Mylenium
    May 24, 2006 at 8:04 am
    Yeah, like Bj
  • Kelly Johnson
    May 30, 2006 at 7:20 pm
    Yeah, I got that. I meant that I’d like to be able to draw lines from point-to-points in a 3D grid and the polygon would be created as a result. More like drawing with a pencil and having the third dimension created.
    Thanks though. I’ve been experimenting and such and am getting the hang of it.
  • Björn Marl
    June 1, 2006 at 10:28 am
    you can use the create polygon tool for this, it works exactly as you described. Just create an empty polygon object and start to draw polygons.
    Cheers
    Bj
