Activity Forums Adobe Premiere Pro generic error premiere cc2018 problem
  • generic error premiere cc2018 problem
    Posted by Vera Gkizelidou on March 28, 2018 at 8:22 am
    Hello ,
    this has been posted before but i haven’t find a solution yet .
    mxf files located on external drive (exFAT)
    files are from different 4k cameras (downgraded)
    (the mxf files were created using davinci software , for each original file there are three files created , one with image and sound and two containing sound only -if this is relevant at all )
    when importing from external disk files would take ages to import (on an imac)
    after I moved them in the external drive files would import (almost) fine .
    so after I moved the project to another pc there was this particular folder who wouldn’t re-link no matter what ( generic import error)
    I copied the folder to another external drive and the same files would link fine .
    but after I moved the files to another location and tried to re-link them I would get the same error .
    I copied the files again to another drive and the problem was solved again.
    I tried to trash the preferences etc but that doesn’t seem to solve the generic error problem .
    Any suggestions ?
    I’m on the edge of a mini nervous breakdown , cc2018 has been giving me all sorts of crazy problems
    Joseph Freeman iii replied 8 years, 5 months ago 2 Members · 1 Reply
  • Joseph Freeman iii
    March 30, 2018 at 2:59 am
    Hi Vera,
    Sounds like a read-write permissions issue with the hard drive folder… I suggest checking permissions, not only the project and files folders, but also the various Premiere Pro temp and auto-save folders.
    Joseph
