Activity › Forums › Apple Final Cut Pro › Generator wont work in FC
  • Generator wont work in FC
    Posted by Clayton Brown on July 30, 2013 at 2:11 pm
    Going to try and make this as clear as possible:
    I have created a generator in Motion 5, and below will run down my steps for creation. When I try to use the generator in FCPX it has an error warning that translates to “Missing Generator”. (https://support.apple.com/kb/PH12711?viewlocale=en_US)
    I am a complete Motion 5 newb and imagine my issue resides somewhere with the creation of the generator;
    Generator purpose:
    To show the remaining length of a segment in the movie for many different segments with different lengths along the timeline. To be represented as a bar filling up per segment. My first generator will be super basic, to just verify the functionality.
    Steps to create my generator:
    1. New Generator
    2. Line tool, draw line, make thick
    3. Shape -> ‘Write On’
    4. Save with new name in my new custom generator sub menu.
    That’s it.
    Gale Dodge replied 12 years, 2 months ago 3 Members · 11 Replies
  • 11 Replies
  • Paul Figgiani
    July 30, 2013 at 4:16 pm
    Clay,
    How did you incorporate the Generator in FCPX? Did you Publish it in Motion to make it available?
    -paul.
  • Clayton Brown
    July 30, 2013 at 4:41 pm
    I did publish it in motion, as a generator, just like your screenshot.
  • Paul Figgiani
    July 30, 2013 at 5:09 pm
    If you want to post it somewhere I’ll pull it down and take a look at it …
    -paul.
  • Clayton Brown
    July 30, 2013 at 5:29 pm
    I zipped the containing folder.. only 12kb’s (seems small..)
    dancevideosdirect.com/ProgressBar3.zip
    Thank you thank you thank you!
  • Paul Figgiani
    July 30, 2013 at 6:25 pm
    https://f-video.s3.amazonaws.com/progressBar3.zip
    My build works here. Didn’t do anything to it except load it in Motion and republish as a Generator.
    -paul.
  • Clayton Brown
    July 31, 2013 at 2:23 pm
    hmmm… confused…
    When I opened motion I created a new FC Generator, when I hit ‘save’ I named it and it shows up in FC.
    Inside of Motion, do I need to look for a ‘publish’ options and ‘publish as generator’? I see ‘publish template’, but not generator..??
  • Paul Figgiani
    July 31, 2013 at 4:16 pm
    You may have started out with a Motion Project instead of a Generator. There is a box in the save dialog to Publish as FCP Generator. At this point the package that I submitted back to you is a Generator. You should be able to run it in Motion and save.
    Or you can manually install it in ~/Movies/Motion Templates/Generators
    -paul.
  • Clayton Brown
    August 1, 2013 at 3:08 pm
    Okay, so I tried a few things and still the same outcome, the ‘missing generator icon’
    What i’ve tried:
    I created a new project in motion and made certain to create a FC Generator from the start. I saved it, found it in FC and poo…
    I went back to a different motion project and did the publish as FC generator as suggested, and still in FC.. Poo –
    I also was able to open your motion project, publish it as FC Generator and still POO.
    I am now wondering if it is an issue with my final cut being version 10.0.5…
    Hence, as we have had issues updating to the newer versions in the past (unconnected media and lost media etc..)
    Has anyone had issues with their projects and events when updating from 5?
    Thanks thanks!
  • Clayton Brown
    August 2, 2013 at 3:29 pm
    Just for those of you who may be interested:
    I updated the FCPX version from 5 to 9 and right off the bat all six of the generators I created work now in FCPX! & None of our projects appear to be negatively effected by the update (as we were very concerned of that).
    Thanks for all you guys help & sorry I may have wasted some of your time.
  • Paul Figgiani
    August 3, 2013 at 3:57 pm
    Cool. Glad to hear you solved this …
    -paul.
