Activity Forums Maxon Cinema 4D Generating polygons with hair
  • Generating polygons with hair
    Posted by Henry Koether on July 27, 2021 at 1:12 pm
    I generated a flat polygon structure for the hair, but now I want to go back to the regular hair (basically, undo the generation of polygons). Since I had saved the file I can’t use undo. Is there any way to go back. I’m afraid to start a new hair object because I would lose all my settings and brushing. Suggestions?
    Jim Scott replied 5 years, 1 month ago 2 Members · 5 Replies
  • Jim Scott
    July 27, 2021 at 3:50 pm
    You should be able to just select “None” for the Generate type to return to regular hair.
  • Henry Koether
    July 27, 2021 at 11:53 pm
    I tried that, but all the hair disappeared when I rendered.
  • Jim Scott
    July 27, 2021 at 11:57 pm
    I rarely use hair, but with just a quick test it seemed like I could switch back and forth between the generators. I’ll have to play around with it some more. Could you post your project?
  • Henry Koether
    July 27, 2021 at 11:58 pm
    Hmmm. I tried a test render of a simple scene (sphere with hair) and it worked to use “none”. Not sure why it wouldn’t with the more complex scene. I thought “none” was the right answer, so I’m glad to see this working on a simple model. Gives me hope. Thanks.
  • Jim Scott
    July 27, 2021 at 11:59 pm
    That’s encouraging. Let us know if you’re able to get your complex scene working.
