Activity › Forums › Adobe Premiere Pro › Generating peak files is running non stop all day.
Posted by Christopher Tegg on December 4, 2012 at 3:18 amSave Media cache files not checked.
How can I stop this ram sapping madness.
Chris
Angelo Lorenzo replied 13 years, 9 months ago 2 Members · 1 Reply -
1 Reply
Angelo Lorenzo
December 4, 2012 at 10:05 amWhat format is your footage and where/how is it stored?
In Preferences > Media you will notice a few settings. One is a section marked “Media Cache Files” with a directory and a box labeled “Save media cache files near originals where possible”. Unchecking this box does not stop the saving of cache files, it simply saves them to the directory specified underneath; a central location for all projects. What’s nice about this option is you can choose whatever works best for you in case you regularly move projects to other edit bays or pull projects from archive.
The media cache database section specifies a central location for the database that keeps track of where these cache files are and what they’re associated with.
I would probably go to each of these locations and delete them manually while Premiere isn’t running. I’d restart Premiere, start a new project and import a few pieces of footage. I’d close Premiere and then reopen to see if the cache files hold steady. It may be a corrupted database. If you’re running Mac then Id use disk utility to make sure you’re good on disk permissions and other disk issues that can wreak havoc on a normal system.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
