Activity Forums Adobe InDesign generating pdf file in cs6 from old cs5 multi page documents are big
  • generating pdf file in cs6 from old cs5 multi page documents are big
    Posted by Paul Taylor on June 11, 2013 at 12:22 pm
    Here is a puzzle,
    I have a 44 page cs 5.5 InDesign document and when I export a single page in the pdf preset ‘smallest File Size’the pdf file comes out at 1.2 mb which is good for me to email for approval
    Now I open the same document in InDesign 6 and save as the export under the same preset ‘Smallest File Size’the same page and I get a 9.8mb. if I delete all the elements on the page so it’s a blank page and pdf page still comes out at 9.8mb, strange. If I copy and past into a new single page pdf the file it come out at 1.2mb.
    I have tried this with lots of documents and it always happens on multi page documents. Single page file doesn’t appear to cause any problems
    I have checked all the image files, they are all reasonable size files. We use Universal type server, but I have disconnected from that, i have even outlined all the fonts, but no joy
    If I make a postscript file and run it through distiller on the ‘smallest setting ‘ it comes out less than 1mb. This is causing our Publishing department problems as we can not upgrade them to InDesign cs6,
    Has anyone come across this problem I would appreciate if anyone can test a brochure/ Here is a puzzle,
    Now if I open the same document in InDesign 6 and export under the same preset ‘Smallest File Size’ the same page comes out as a 9.8mb pdf. if I delete all the elements on the page so it’s a blank page and the pdf page still comes out at 9.8mb, strange. If I copy and past into a new single page pdf the file it come out at 1.2mb.
    I have tried this with lots of documents and it always happens on multiple page documents. Single page file do not appear to cause any problems
    Has anyone come across this problem I would appreciate if anyone can test a brochure/multiple page documents from cs5.5 and open in cs6. i need to see if this is local to our environment.
    paul
    Paul Taylor replied 13 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
