Activity › Forums › Adobe After Effects › Generating keyframes between existing keyframes
  • Generating keyframes between existing keyframes
    Posted by Alan Shields on March 13, 2009 at 1:00 am
    I am working on a particular project that requires keyframe data for the length of the project, anywhere from 8 seconds to 5 minutes. This also applies to more than one attribute, ie: transformation, rotation, scale, etc. So far I have manually been selecting the attributes after my main keyframes are in place and frame by frame clicking the add keyframe for every keyframe between each main keyframe I placed. Does anyone out there know of a way to generate keyframes between 2 existing keyframes without moving any of the attributes? I have used tools like the wiggler and exponential scale, but these both only effect position attributes and alter the position of what I am animating respectively. Any information anybody may have or has encountered this problem would be a huge help. Thanks
    Bartek Skorupa replied 17 years ago 3 Members · 3 Replies
  • Curious Turtle
    March 13, 2009 at 5:16 pm
    Hi Alan,
    Try this:
    i) Paste this expression into the attribute you want to bake the keyframes on:
    a=1/thisComp.frameDuration;
    wiggle(a,0)
    ii) Right-click on the first keyframe and choose “Keyframe Assistant > Convert Expression to keyframes”
    This will create a keyframe on each frame for you.
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Alan Shields
    March 13, 2009 at 5:40 pm
    Ben,
    This works perfectly! thank you much for the help!
  • Bartek Skorupa
    September 19, 2009 at 11:17 am
    I would only change one thing. Instead of writting:
    wiggle(a,0)
    I would write:
    value
    Bartek Skorupa
    Warszawa, Poland
