Activity › Forums › Adobe After Effects › Generating grids
Generating grids
Posted by Alfred Hammer on September 29, 2011 at 8:19 amI’d like to generate a grid inside of a custom shape. I tried creating a new solid, asking it and then generating a grid, but the grid applies on to the entire solid. I also tried making a shape layer and then generating a grid inside of it, but no luck. Is there a way I can go about doing this?
Thanks in advance.
Walter Soyka replied 14 years, 11 months ago 5 Members · 12 Replies -
Alfred Hammer
September 29, 2011 at 8:26 amSomething like 0:30 of this video.
https://www.youtube.com/watch?v=9MeaaCwBW28Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Brian Charles
September 29, 2011 at 12:47 pmHave you tried to distort the grid using Mesh Warp over the grid layer?
Alfred Hammer
September 29, 2011 at 1:53 pmI just tried the using the eraser tool, takes a lot of time… but hey, atleast it works. If you do know another workaround, I’d be grateful
Walter Soyka
September 29, 2011 at 2:31 pm[Alfred Hammer] “I’d like to generate a grid inside of a custom shape. I tried creating a new solid, asking it and then generating a grid, but the grid applies on to the entire solid.”
From Render order and collapsing transformations [link]:
Note: Some effects ignore masks on the layer to which they’re applied. To have such an effect operate on a masked layer, pre-compose the layer with the mask applied, and then apply the effect to the pre-composed layer. (See About precomposing and nesting [link].)
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Roland R. kahlenberg
September 29, 2011 at 4:04 pmBrian’s suggestion WORKS! You’ve quite obviously have it all backasswards. In fact, the FreeFormAE plugin that is bundled with AE should also do the trick f you require 3D deformations of your grid.
If the grid is offending your vision, after applying the Mesh Warp then you should temporarily switch off the Grid effect as you manipulate the appropriate points to their destination.
Cheers
RoRKIntensive AE & Mocha Training in Asia.
Alfred Hammer
September 30, 2011 at 9:34 am -
September 30, 2011 at 11:13 amCan we just forget about mask shapes for this one? It isn’t required at all.
All you need to do is to create a solid at the size that you want. Then apply the Grid effect followed by FreeFormAE or Meshwarp and distort accordingly.
HTH
Eric Santiago
September 30, 2011 at 5:51 pmJust as Roland suggested this is best unless you have access to 3D software.
