Activity › Forums › DaVinci Resolve › Generating .cube LUT’s for visual effects artist
Posted by Greg White on July 13, 2012 at 5:27 pmHI i just graded a project shot on red, i exported 2k DPX files, the client is working at a visual effects house and they require .cube luts. i tried several different ways but nothing worked, dose any one know a easy way to do this.
Thank you
Michael Stirling replied 13 years ago 4 Members · 8 Replies -
Andi Winter
July 13, 2012 at 5:47 pmlast time my approach was like this:
1. generated a log/rec709 lut with arri lut generator
2. generated the r3d proxies in davinci with a “first light grade”, treated red files as log film. loaded display lut from 1 -
Greg White
July 13, 2012 at 6:12 pmnot sure if i understand you, but what im trying to do is generate a .cube lut from davinci and send them to a visual efx company.
https://www.linkedin.com/pub/gregory-white/13/4a9/336
Andi Winter
July 13, 2012 at 6:53 pmsorry for my strange answer. i didn’t have much time then…
why does the fx-guy need your lut? in my case the fx guy didn’t want to use the
original 3ds (too slow to work with). so we decided that i do a pre-grade and then
give him that prores444 files at 2,5k in log. that way he could work well and fast
and i didn’t lose too much information in terms of dynamic range for the final grade.but what is your situation exactly? did you generate the 3d-lut in resolve and it didn’t
work or was there some other problem? (look into the manual, there is a chapter which
explains the 3d-lut generating, you just have to load a certain dpx file etc.) -
Greg White
July 13, 2012 at 7:26 pmthanks , ya i think i figured out the process, here it is from the manual, really Black Magic? all this to create 1 lut
Workflow A:
1. Set your resolution to High Definition within the Config screen.
2. Load the trim_lut0.dpx file located at /Library/Application Support/Blackmagic Design/ DaVinci Resolve/trim_lut0.dpx into the Browse screen’s media pool. Within the Color screen you will now see the Trim LUT file within the thumbnails.
3. Select a normal image clip on the timeline and color grade the desired offset or effect. You can grade this image like any other. Once done, select the Trim LUT clip on the thumbnail timeline with your mouse to make it the current clip.
4. With the Trim LUT file as the current clip, using the center mouse button, click on the clip you just graded with the desired offset grade. This offset grading will now be applied to the Trim LUT file. (This is a standard DaVinci Resolve copy grade operation).
5. Then, within the Config screen LUT tab, assign a name to the new LUT to be generated using the ‘Save LUT as’ window.
6. Clicking on the Generate LUT button will create the new LUT that is an offset grade. It’s the grade you made to the original image. This LUT can now be selected like any other.
7. Update the LUT list that’s at the top of the LUT tab and select as an input, output or display LUT as required. You can also use the LUT on the color page in any node.
The new LUT will appear in the 3D LUT options and can be used in any of the places DaVinci Resolve normally uses 3D LUTs. It is also possible to capture an external Trim LUT or generate one with the Resolve LUT configuration and resolution by placing this Trim LUT Clip into an external device that applies a LUT.https://www.linkedin.com/pub/gregory-white/13/4a9/336
Juan Salvo
July 13, 2012 at 7:43 pmIt’s covered pretty well in the manual… but that is a good summation. All of this should be much, much easier in v9.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
Michael Stirling
August 21, 2013 at 10:13 amWell, it’s exactly the same in v9 other than that this workflow description has totally disappeared from the manual! Thanks for posting it Greg – I’m not sure I’d have thought to read the v8 manual for this.
MIchael
Juan Salvo
August 21, 2013 at 1:27 pmUmmmm all you have to do now is right click on the Thumbnail and click on “Generate 3D LUT”. That’s covered on page 560 of the manual.
And like i said, waaaaaaay easier.
color/post/workflow
https://JuanSalvo.com -
Michael Stirling
August 23, 2013 at 8:12 amHa!
Thanks… I did search through the manual for quite a while. Still works the old fashioned way too btw 🙂
