Activity › Forums › Maxon Cinema 4D › generating and simulating large volume of particles
  • generating and simulating large volume of particles
    Posted by Ekpeti Chuks on June 20, 2016 at 4:52 pm
    Hi everyone
    Please am working on a project whereby I have to generate large volume of particles thy size of a grain of rice, to fill a large tank, with a hose sucking the particles of and depositing them in another vessel….please I wanna know wish technique will be easier to achieve that with minimal stress on my computer. Thank you
    Ekpeti Chuks replied 10 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    June 26, 2016 at 5:36 am
    this is way late but FWIW, minimize the rice grain to the smallest number of polys – use textures to make it appear smooth and with whatever detail you need. Second, cheat. Do not attempt to fill a large tank with something the size of a grain of rice just make it look like you did (unless you have to actually show that – but it’s not likely you really have to). It doesn’t have to be a full tank of rice (or whatever) to stick a hose into to suck it up only enough actual particles to show the pick up, what’s under that can be a filler solid object that is never seen or has a texture on it to look correct if it is seen…
  • Ekpeti Chuks
    July 3, 2016 at 8:33 am
    Tnx a lot….i did something else but I think I will try this method in subsequent projects
