Activity Forums Adobe After Effects Generating an artificial key-light shadow in AE?
  • Generating an artificial key-light shadow in AE?
    Posted by Richard Christy on July 21, 2011 at 4:03 am
    In my studio, I’m using a three point lighting setup, with a subject against a screen.
    The thing is, I have to reposition the lights in a non-traditional way in order to over expose the screen for post-production purposes (it’s a desired effect so we’re doing this on purpose).
    This issue in doing this, is that the subject in the foreground is lit fairly evenly (or flatly, with no key-light shadow as this light is moved in more closely to achieve the desired effect of the screen).
    I’m able to color correct the foreground subject with filters and get a nice, crisp look. However, one noticeable draw back is the lack of slightly darker side (or shadowed side) of the face you typically get with a three point setup.
    Is there a plug-in or method in AE to generate an artificial key-light shadow on one side of the subjects face without altering the overall color in general?
    Walter Soyka replied 15 years, 2 months ago 4 Members · 6 Replies
  • Tudor “ted” jelescu
    July 21, 2011 at 6:54 am
    Why do it in post when it would be so easy to bring in additional lights in the studio? No filter can simulate what a real light does.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Richard Christy
    July 21, 2011 at 3:54 pm
    It’s hard to describe the studio setup other than, the current setup is what we have to work with. We have neither the resources or the room to bring in any more lights, or move the subject. I know the conventional wisdom is to always adjust issues at the time instead of after the fact, but in this case, it’s inevitable.
    However, I should mention the foreground subject does not move. They are always in a stationary position for the duration of the video.
    I have seen AE plug ins that let you designate an area you wish to focus on (IE: using a simple, circular mask type cursor) and it generates the desired effect in and around this area.
    Are you saying there is no such method that will allow to generate the key-light shadow?
  • Barend Onneweer
    July 21, 2011 at 4:42 pm
    If you can’t bring additional lights, can you put a piece of black fabric or foamboard on one side of the subject? This ‘negative bounce’ will help creating a less flat look.
    Other than that, you can manually mask out your highlight areas and lift them a little using any colour grading tool.
    Raamw3rk – digital storytelling and visual effects
  • Richard Christy
    July 21, 2011 at 5:08 pm
    It is a screen, but we’re not chroma keying. We’re going for a desired effect and the current lighting setup proves to get us what we need. The lack of shadow is the unwanted bi-product.
    I under this is a manual process of adding the shadow back in, and I’m willing to give it a try. That’s actually why I’m posting. I just need to know WHAT method. Not sure how to go about it…
    My assumption is that, at some point, someone has ran into a similar problem and fixed it in AE after wards. I just need to find this method so I can give it a try.
    My Google searches always return results for shadows in a chroma key environment (and not really the same thing in this case).
  • Barend Onneweer
    July 21, 2011 at 5:13 pm
    Your description is a bit confusing. A picture would probably come in handy right about now.
    But it sounds like you want to manually draw in the highlights. So create an adjustmentlayer, mask the highlight areas, add a little feather to the mask and use Levels, Curves or Exposure to lift the highlights a little.
    For more detailed advise you really should show an image of what you’re working with.
  • Walter Soyka
    July 21, 2011 at 5:28 pm
    Can you post a screen shot of your footage?
    If I absolutely had to do this in post, I would try to track points or features on the subject’s face. Next, I’d hand-paint a depth map of the face. After that, I’d try to morph the depth map according to the tracked features as the subject moves. I’d use a Sobel filter to attempt to convert the depth map to a normal map, and then I’d use normals-based re-lighting to attempt to realistically cast the shadows.
    After all that time and effort, I’d be totally disappointed in the results.
    Have you considered exposing the subject properly, rotoscoping the subject, and manipulating the screen background in post?
    Walter Soyka
