Activity Forums Apple Motion Generate water effect
  • Generate water effect
    Posted by Bryanman on February 28, 2007 at 5:43 pm
    I need to create a shot where a fire hose appears in the frame and then a stream of water (with alot of force) comes out of the hose. Any ideas on a simple way to simulate the water stream (because of limitations I need to do this in post).
    Thanks in advance
    John Czerwinski replied 19 years, 6 months ago 2 Members · 1 Reply
  • John Czerwinski
    March 8, 2007 at 6:56 pm
    Try “Spout” under the Particle Emitter. Bring up the Birth Rate, Speed & Speed Range.
    Good Luck
    John
