Activity › Forums › Square Box CatDV › Generate proxy utilize Matrox Compress HD chip?
Posted by Jason Brown on March 9, 2011 at 5:50 pmCan generate proxy use a CompressHD card from Matrox?
Jason Brown replied 15 years, 4 months ago 2 Members · 2 Replies -
Bryson Jones
March 9, 2011 at 6:12 pmI’ve not done it, but since CatDV uses the QT engine and the Matrox works with the QT engine, I’m sure you could just select it as a codec option when you set up your previews.
This is how folks do it with the elgato accelerators.
Also, for the record, you can also hand off a proxy generation job to Episode or any other heavy duty compression engine if you need “big boy pants”.
bryson
bryson “at” hidefcowboy.com
hidefcowboy.com
Jason Brown
March 9, 2011 at 9:48 pmI just love the speed…I’m a huge advocate for the CompressHD…not used the Elgato though.
I’ll look for you at NAB! 🙂
-Jason
