Activity Forums DaVinci Resolve Generate Proxy function not available
  • Generate Proxy function not available
    Posted by Sean Lennon on February 4, 2022 at 8:11 pm
    Haven’t been able to find answers as to why in my Resolve 17.2.1 I don’t have the generate proxies function available. Anyone any ideas?
    Thanks.
    Jon Zanone replied 4 years, 6 months ago 2 Members · 1 Reply
  • Jon Zanone
    February 6, 2022 at 12:54 pm
    When you right-click on the media, you should get a menu that includes ‘generate optimized media’. You don’t have that?
    Optimized media is the same as proxy media – but you’ll need to go into your settings, choose ‘Master Settings’, scroll down a bit and look for ‘Optimized Media & Render Cache’. My system defaults to higher quality media, so I make sure to select something I know is less than the worst quality media I have.
    You can also make sure to select ‘Playback – Render Cache – Smart’ in the main menu. Your system will generate optimized media during inactive periods.
