Activity Forums DaVinci Resolve Generate LuT in Resolve
  • Generate LuT in Resolve
    Posted by Nikolas Panteris on December 3, 2013 at 11:24 am
    Hi All,
    This probably is something wrong with the settings or the process I am following but here’s the case…
    I have tested this with various footage (709, log, dpx, mxf… etc.) and 24/25 ACES, YUV all the possible combinations and on 3 different stations… all using resolve 10.00lite.073
    I am getting bizarre results trying to use a LuT that I have created on Resolve using a grade.
    When I apply the 3D LuT the image looks as it’s been solarised and when I looked into the .cube file as a text I see a lot of 0.000000 values quite high on Red and Blue channels, which agrees with what I am seeing.
    This is the same if I use the LuT on the node or in the Preferences.
    Any ideas?
    Thank you in advance…
    Nik
    Pedro Conforti replied 11 years, 11 months ago 2 Members · 1 Reply
  • Pedro Conforti
    June 4, 2014 at 6:23 am
    Hey Nik, I’m on the same boat as you… would there a good soul be around to the rescue? Or have you found the solution?
    I have been trying to create a simple, primaries only LUT for ages, but it always gives me this bizarre inverted colors image when I try to apply it on Resolve.
    This is what I am doing (with a single node, primaries only grading): Project Setting > Lookup Tables > Generate LUT From Current Grading
    Can’t understand why this doesn’t work. I have been trying this apparently simple procedure since Resolve v9, with no sucess. Tried it on 3 macs with different GPUs…, and always the same result.
    If someone can shed a light over this I’d be very grateful. It would help a lot – and also prevent me to go bananas over this!
    Pedro
    Pedro Conforti :: Colorist
    pedroconforti.com
    DaVinci Resolve
    Mac Pro 8 core 2.26Ghz 48Gb RAM
    OSX 10.8 Mountain Lion
    GTX 570 2.5Gb (macvidcards) + GT120
    Tangent Element
    Decklink HD Extreme 3D
