Activity Forums Apple Final Cut Pro Legacy Generate Custom mask in FCP?
  • Generate Custom mask in FCP?
    Posted by Gary Ellison on August 30, 2010 at 7:47 am
    Hey all,
    In dire need of help if anyone can! I need to be able to make a custom layer mask for my footage to make it boxed at roughly 1080×1080.
    I need to make a box for my footage to go in and I need to be able to edge feather the mask so the edges aren’t sharp.
    I’ll be basically doing this to two seperate pieces of footage and then creating a split screen just like in 500 days of Summer:
    https://www.youtube.com/watch?v=pKDj7DJZMnI
    I know I could crop each shot, but we’re probably going to have to reframe a lot of shots and it’d be SO much easier if we could have a generator mask just to put over it.
    Any help would be so much appreciated!
    Thank you
    Gary
    Bret Williams replied 16 years ago 4 Members · 5 Replies
  • Bret Williams
    August 30, 2010 at 3:47 pm
    Crop it in the motion tab. If it’s a sequence, nest it then crop in the motion tab.
  • Gary Ellison
    August 30, 2010 at 4:08 pm
    Hey thanks for getting back to me.
    That is the easiest way and I’ve got some great results in terms of look, but as I said a lot of these shots will need to be reframed within the box. Obviously with a crop the box will move with the image if I try and do that, so I need a mask on a seperate track that’ll stay put whilst I move the footage.
    Am I making sense?
  • John Pale
    August 30, 2010 at 5:45 pm
    Why not just create what you want in Motion, if the FCP masking tools aren’t cutting it for you?
    Motion has great masking capability and is well integrated with FCP.
  • Sachin Desai
    September 1, 2010 at 1:50 am
    use photoshop for making mask in any shape, scale design, edges in black and white and use layer mode to luma for the footage
    Sachin Desai
  • Bret Williams
    September 1, 2010 at 4:18 am
    Sure. I often do Photoshop type work in FCP. If you just want a black matte with two holes, just create 2 black boxes next to each other. Press shift+N to make a freeze of them. Add an alpha invert filter and freeze it again. Or any number of ways to get to a freeze with two transparent holes. Of course a png from Photoshop works easy too, but sometimes it’s just quicker on FCP for simple stuff. Anyway, just put the matte on top and move the clips into place beneath.
