Activity › Forums › Adobe After Effects Expressions › General: What text editors and other tools do you like for AE expressions?
  • General: What text editors and other tools do you like for AE expressions?
    Posted by Phil Aupperle on April 3, 2016 at 5:23 pm
    I wanted to see what text editors and other tools people like for working on AE expressions. Editing in the layers panel is a drag.
    -I have been using Smultron forever out of habit and laziness, but it’s very no-frills.
    -I just tried Adobe’s Brackets, but it’s annoying that it flags all kinds of javascript formatting errors that don’t matter for our purposes.
    -TextWrangler seems pretty good, so maybe I’ll test drive it for a while.
    -“Expressionist” on AEscripts looks like the jam. (I just bought it while I was typing this post, so I hope so!!)
    -I have been archiving my expressions in Evernote for years (along with everything else in my life) because it’s searchable, accessible from anywhere, etc.. It’s super fast to just copy paste stuff and not get bogged down with organizing it.
    -I just got the “Expression Toolbox” script the other day, and it seems helpful. I haven’t spent much time with it yet, but it seems like you have to be careful not to screw up your expression library when you’re trying to modify expressions for specific instances.
    What do you like?
    Santi Agustí replied 10 years ago 6 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    April 3, 2016 at 6:45 pm
    Almost always Notepad. 🙂
    Dan
  • Miguel De mendoza
    April 4, 2016 at 12:18 am
    I think the best is Notepad ++, it’s free and recongnizes allmost all languages. But I usualy work with layer panel (it is a matter of getting used) or in Extendscript Toolkit.
  • Jakob Wagner
    April 4, 2016 at 11:32 am
    The expressionist looks great, but I havn’t tried it yet. For longer expressions and scripts, I always use sublime text. It works really great with almost any kind of script.
  • Phil Aupperle
    April 4, 2016 at 7:30 pm
    Now that I’ve had a day to bang on Expressionist pretty hard, I’d say it’s going to be a major tool for me from now on. The ability to grab expressions out of properties, and then blast them back onto multiple layers simultaneously without copy-pasting is awesome. This means you can actually keep the ram preview going while you tweak an expression, reapply it to multiple layers, and see the results immediately. I still think it’s a good idea to have another text editor open so you can keep variations, save text files, etc., but for AE productivity the extension is huge. Also, the ability to catch open perens and brackets without my eyes going googly is a big bonus. 😉
  • Stephen Dixon
    September 8, 2016 at 1:58 pm
    I’ve developed a technique where you can use text layers as expression editors. This has a couple of advantages: you can use one text layer to drive multiple layers and properties meaning that you only have to update the expression on all the layers. Also it updates as you type which is frankly awesome, and lastly you can see the expression in the comp window if you want, in whatever font you like with optical kerning and everything.
    The biggest down-side of this technique is that you don’t have access to the pick-whip and the expressions drop down. If you’re a newb expressions writer then this is probably not for you, but for simple expressions that you want to apply to hundreds of layers it really is the bomb.
    Basically it invoves using the javascript eval() function, that is sometimes used to drive expressions from external files. But there’s a trick to getting it to read text layers – you need to use the value property of a property. Full details on how to do it here: https://blob.pureandapplied.com.au/using-text-layers-as-expressions-in-after-effects/
    exp = thisComp.layer("expressionSource").text.sourceText.value;
    eval(exp)
    Stephen Dixon
    Editor, Animator, Motionographer
    Museum Victoria
  • Phil Aupperle
    September 8, 2016 at 5:12 pm
    That. Is. Awesome.
    That unlocks a huge amount of potential. Can’t wait to start testing this!
  • Santi Agustí
    September 8, 2016 at 9:59 pm
    oh Stephen, glad to see that! since forever I’m using a very simmilar snippet to store the most common expressions I use (like different kinds of bounces, or some extended wiggles, etc), but referenced to an external comp called “scripts”
    I use this variation, but is the same:
    eval(comp("scripts").layer("bounce01").text.sourceText.toString());
