Activity Forums DSLR Video general use lens for 7D
  • general use lens for 7D
    Posted by Ashley Davis on March 29, 2011 at 11:07 pm
    I’m about to order a Canon 7D body and I need a good everyday lens. At the moment, I’m only getting one lens but will eventually get others too. So I am looking for a good functioning high end lens, that is good for both video and photography and have a budget for around £750ish.
    At the moment, I am looking at either the Canon 17-55mm f/2.8 IS EF-S adn the Canon EF-S 15-85mm. (heard nothing but great things about the 17-55 but the others seems better on both ends.
    Can anyone give me some advice.. again, this will be an everyday lens, good for video and photo’s and I will later invest more in other lenses.
    Zane Barker replied 15 years, 5 months ago 5 Members · 6 Replies
  • Robbie Carman
    March 30, 2011 at 12:26 am
    Well I would put a vote towards the 17-55. This lens is absolutely one of the sharpest lenses in my bag. Great for photos, good for video (as good as photo lenses can be). I actually sold the Canon L 24-70 I had for the 17-55. Granted its EF-S so it will only work on cropped bodies like the 7D but its a really really good lens. On the long end don’t forget that you get help from the 1.6x crop factor of the 7D. On the short end you might want to consider a super wide angle 10-12 mm to fit the wides you might need.
    Robbie Carman
    Colorist and Author
    Check out my new Books:
    Video Made on a Mac
    Apple Pro Training Series DVDSP
    From Still To Motion
    Twitter
    Blog
  • Rick Diamond
    March 30, 2011 at 10:10 pm
    The 17-55mm lens is equivalent to an “L” series lens. This is Canon’s top of the line.
    The reason it isn’t branded an “L” series is because it’s an APC lens.
    It has a constant 2.8 aperture which is very important for video.
    good luck
    Rick
  • Ashley Davis
    March 30, 2011 at 11:19 pm
    This is a very stupid question can but it can it be adjusted for photos can’t it?
  • Rick Diamond
    March 30, 2011 at 11:38 pm
    Yes. As it is zoomed through it’s range, it maintains the aperture. You can set and change any aperture you desire.
    Rick
  • Malcolm Matusky
    April 1, 2011 at 12:23 am
    I have the Canon 17~55 f2.8 IS, Great lens, also have the Tokina 11~16 f2.8 and Canon 70~200 f4.0 IS. I use the 17~55 most of the time, it lives on the 7D and my next used lens is the 70~200 though I will be adding an extension tube to be able to focus closer, the Tokina I rarely use, but for car interiors or other super tight spaces it works.
    Malcolm
    http://www.malcolmproductions.com
  • Zane Barker
    April 1, 2011 at 6:56 am
    [Ashley Davis] “At the moment, I am looking at either the Canon 17-55mm f/2.8 IS EF-S adn the Canon EF-S 15-85mm. (heard nothing but great things about the 17-55 but the others seems better on both ends. “
    https://www.borrowlenses.com
    Why not rent then each ant find out which you like better.
    **Hindsight is always 1080p**
