Activity › Forums › Blackmagic Design › General Questions
General Questions
Posted by Michael on August 4, 2005 at 4:23 pmGeneral Questions…
I
Luke Maslen replied 21 years ago 3 Members · 3 Replies -
Michael Robert
August 5, 2005 at 12:54 pmLuke,
Thank you for your detailed response! I appreciate the time you have taken to answer my questions.
In your conclusion you talked about DV being a lossy compression and therefore when adding gfx and renders, it can/will suffer quality loss. I agree with you, which is why I like to up convert my current DV projects to the Matrox mjpeg codec for editing and compositing. Are you suggesting that instead of digitizing a DV tape in it
Luke Maslen
August 9, 2005 at 2:37 amHi Michael,
[Michael] “In your conclusion you talked about DV being a lossy compression and therefore when adding gfx and renders, it can/will suffer quality loss. I agree with you, which is why I like to up convert my current DV projects to the Matrox mjpeg codec for editing and compositing.”
MJPEG is also a lossy codec and the very process of transcoding from DV to any other compressed codec immediately results in the loss of some quality. All compressed video codecs, of which I am aware, use lossy compression and suffer from generational data loss. Some may be better than others but the only way to prevent such loss is to work with uncompressed video.
[Michael] “Are you suggesting that instead of digitizing a DV tape in it
