Activity Forums Apple Final Cut Pro Legacy General Error/Out of Memory
  • General Error/Out of Memory
    Posted by Courtney Wallin on February 13, 2013 at 7:11 pm
    I have currently been working on a project for the last month. I took a system update earlier this morning which upgraded my FCP from 6.0.5 to 6.0.6. It’ll open my project, but when I go to open my sequence, I get the “General Error” followed by “Out of Memory”.
    I’m able to open my clips, but not my sequences, which hold all my hard work 🙂
    I’ve tried uninstalling, reinstalling. Typically when it opens and says that you’re in a newer version, saving it will keep it in that format, that does the trick. Not so much in this case.
    Specs:
    MacBook Pro
    FCP 6.0.6
    Mac OS X 10.6.8
    Intel Core 2 Duo
    2.5 GHz
    Memory: 2 GB
    I’m trying to avoid upgrading my FCP, because that’ll also require me to upgrade my OS.
    Help?
    Courtney Wallin replied 13 years, 7 months ago 2 Members · 2 Replies
  • Simon Modery
    February 14, 2013 at 9:14 am
    Try this:
    Copy the sequence into a new FCP project (through copy and paste), then close the old project, then close FCP. Now open FCP again and try to access the sequence.
    Head of Postproduction
    Motherlode
    http://www.simonmodery.com
  • Courtney Wallin
    February 15, 2013 at 7:35 pm
    Simon,
    With fingers crossed, this still did not work 🙁 I feel like i’ve tried every possible combination and still no results. I’ve even uninstalled the version I had, and upgraded to 7…same errors.
    The good news is I was able to compress out my sequence and it saved my clips. I’ll have to start over, but at least it’s all there and marked-plus I can see what I had worked on via the H.264 compression.
    Thanks so much for your feedback!
    Courtney
