Activity Forums Apple Final Cut Pro Legacy general error when rendering
  • general error when rendering
    Posted by Zik Staav on June 17, 2008 at 5:54 am
    hey there.
    i’m working with footage which is a .jpeg sequence converted by quicktime pro into a 24fps .mov file.
    when loaded into FCP 6.0 on my macpro 2×2.8Ghz 10GB RAM machine, in an NTSC timeline, the footage won’t render without giving a “GENERAL ERROR” message.
    i tried a 23.98 and a 24 fps sequence, and got the error message both times.
    any ideas?
    thanks.
    -drechataber
    Paul Dickin replied 18 years, 3 months ago 2 Members · 1 Reply
  • Paul Dickin
    June 17, 2008 at 9:15 am
    Hi
    Conform your QT movie’s frame rate using Cinema Tools to the timeline frame-rate.
    The only time I’ve had rendering General Error problems is with dodgy frame-rate source clips.
