Activity Forums Apple Final Cut Pro Legacy General Error when I try to render out Snapz ProX video
  • General Error when I try to render out Snapz ProX video
    Posted by James Coppens on May 10, 2011 at 6:00 pm
    So here is my issue. I’m creating a tutorial on my personal website using Snapz ProX as my screen capture video. When I try to import all the movies to final cut pro and put them all together in a sequence to render I get a “general error” right when it gets to the end. I tried importing the footage to compressor and compressing to apple ProRes 422 and then bring it into FCP but I still get the same problem
    To add more to the issue, It is at a very strange pixel aspect ration (1079×606) and the flowplayer video player only will play flv or mp4 so I may be creating the sequence settings wrong.
    Any help at this point would be much appreciated.
    https://www.jimmycoppens.com
    Dennis Radeke replied 15 years, 4 months ago 4 Members · 6 Replies
  • Shane Ross
    May 10, 2011 at 6:27 pm
    FCP is a video editing application that works with standard video frame sizes and frame rates. If your footage falls outside standard video formats and frame sizes…it will take issue.
    And 1079×606 is NOT standard. Converting to ProRes won’t help…it’s the frame size that’s the issue. If you plan on bringing screen capture footage into FCP, it needs to be framed as 1920×1080, 1280×720 or 720×486 or 720×480. EIther that or use different editing software. I’m sure Adobe Premiere can handle this.
    Shane
  • James Coppens
    May 10, 2011 at 6:36 pm
    Shane,
    Thanks for the quick response! So even if you modify the settings of the sequence to “custom” and set the pixel aspect ration to square it will still crap out on me? I’ve done something similar before with h264 but what came out was definitely not very pretty…
    I do have very limited experience with FCP and I’ve only used it for my personal videos on youtube and my website. Is FCP more robust if your using explicitly defined and common aspect ratios?
    Jimmy
  • Shane Ross
    May 10, 2011 at 6:39 pm
    FCP is designed to work with video formats. Anything that strays from that causes issues. Yes, you can change the sequence settings to match what you have, but FCP won’t like it…and will most likely crap out. This is why when I did use SnapzPro, I made my work area 1280×720. But now I use Screenflow, that allows me to edit right within the app.
    Shane
  • James Coppens
    May 10, 2011 at 6:49 pm
    Many Thanks Shane.
  • Rafael Amador
    May 10, 2011 at 8:01 pm
    James,
    Cutting and exporting native, codecs and size shouldn’t be a problem, as long as you avoid any video rendering.
    The problem is that when you “cut” any GOP based format (and I guess Snapz is) there is always some “rendering” involved. When you cut a GOP, the GOP needs to be rebuilt (conformed).
    With more familiar GOPs formats (MPEG-2, MP4), QT/FC has no problem to conform the stuff, but seems that Snapz codec is not that easy.
    Anyway I would try to make some cuts and try to export without rendering from FC.
    rafael
    http://www.nagavideo.com
  • Dennis Radeke
    May 12, 2011 at 2:09 pm
    [Shane Ross] “I’m sure Adobe Premiere can handle this.”
    Indeed it does. Create a new sequence, click on the sequence settings tab and then change the editing mode to desktop, the aspect ratio, etc.
    OR…
    You can just import the clip into the project and drag it to the ‘new item’ button. It will automatically create a sequence based on the settings of your video.
    In most cases, it plays just fine. Of course, mileage may vary.
    Cheers,
    Dennis
