Activity Forums Apple Final Cut Pro Legacy General Error when exporting
  • General Error when exporting
    Posted by Fernando Eloy on March 17, 2008 at 10:39 am
    hi there,
    I am trying to export my sequence using quicktime conversion since I need to output it to a PC based studio. I have tried to export from the actual sequence and from a Final Cut movie file I made to create CD’s. Same problem: after a while fails and gives the message “General Error”
    I am using FCP pro 6 running on Mac Book Pro (last version) 2.5 Ghz Intel Core Duo; 4GB 667 DDR2 SDRAM
    Since I can’t also print to tape (image freezes in some sections) I don’t know what else to do.
    Your help would be greatly appreciated
    Thanx
    Eloy
    Zane Barker replied 18 years, 5 months ago 2 Members · 6 Replies
  • Fernando Eloy
    March 17, 2008 at 11:56 am
    forgot to say that I am working with HDV 1080i
  • Zane Barker
    March 18, 2008 at 7:47 am
    Try exporting a file with out quicktime conversion, just keep it the same settings as the time line. If it fails there then it could be that you are dealing with some bad/corrupt media.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Fernando Eloy
    March 18, 2008 at 7:56 am
    thanx Zane!
    That is what I am trying to do byut I don’t know which export shall I do in order to have it read on a PC system.
    Now I am trying using compressor. But most of the .mov I get the PC does not read…
  • Zane Barker
    March 18, 2008 at 8:08 am
    [fernando eloy] “That is what I am trying to do”
    That is NOT what you said you were doing. You said
    [Fernando Eloy] “I am trying to export my sequence using QuickTime conversion”
    Select export quicktime movie NOT QuickTime Conversion.
  • Fernando Eloy
    March 18, 2008 at 8:29 am
    sorry. you are right.
    so if i do not use the quicktime conversion to export what shall use in order to get a quality file able to be read by a PC system?
    thanx again
  • Zane Barker
    March 18, 2008 at 4:18 pm
    if you can get a good file that way then bring it use compressor, or pull it back into FCP and see if you can lay that back to tape.
