General Error on Export no matter what I do?
Hi all –
I’ve got about a 2 hour project that I’m trying to export out of FCP7.
I shot .MOV, 23.97fps on a T2i, used mpegstreamclip to convert to ProRes 422.
On Quicktime Export, I get a general error about 3% of the way in.
When I try to export everything in 3 minute chunks, things go fine. Any larger, and I get a ‘General Error’ message.
I’ve had my scratch disk set to the external drive that the files are on, and on my Mac. (27″ 16GB ram i7 core, 4GB video). Didn’t make a difference either way.
I’m aware that I may have a bad render – I’ve deleted render files and re-rendered about three times. I’ve even re-converted the master file (that I originally thought was the problem) and connected the media to the new ProRes 422 file.
When I try to export as a Quicktime Conversion, the export starts at 7%, gets about halfway thru and gives me a I/O error.
When I try to send to Compressor, it fails to do so, regardless if Compressor is open or not.
Any help on this? I’m desperate to get this completed, but nothing I do seems to matter.
One last note – I’ve exported this thing as a Quicktime file before, and then burned it to a DVD using Compressor. It had some issues, so I had to fix them and then re-export, which is where I’m stuck.
