Activity Forums Apple Final Cut Pro Legacy GENERAL ERROR- NOT FOUND
  • GENERAL ERROR- NOT FOUND
    Posted by Cem Yildirim on February 25, 2008 at 5:22 pm
    When the playhead comes to a certain area of the sequence, FCP freezes then I get this message “NOT FOUND” then it says” “GENERAL ERROR” The master clip plays fine in the viewer, and I try to replace it, but does not work . What seems to bo the problem and what can I do to fix it? Thank you very much…
    http://www.cemyildirim.i8.com
    Jeremy Garchow replied 18 years, 7 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    February 25, 2008 at 6:02 pm
    Try reconnecting to the clip. If that doesn’t work, recapture it. ALso try deleting render files. Have you checked to make sure the clip is actually on the scratch disk and not a render file?
    Jeremy
  • Cem Yildirim
    February 25, 2008 at 7:34 pm
    Deleting render files and re-rendering worked. Thanks a lot.
  • Jeremy Garchow
    February 25, 2008 at 7:42 pm
    No worries.
